mease DP installation help
turbobooster
hey guys i have the mease 3 inch dp wit dump but not sure on how too hook it up as far as the bottom of it where the catalytic converter is at? i mean the dp is 3 pieces but if i wanna hook up my dump i have to remove the cat and get the other end of the dump pipe flange tp the rest of my exhaust system my problem is whats the best way to hook up my dp and dump and still be able to switch it back to my cat when it comes time to do smog ill need my cat back on but i also dont wanna weld the dump pipe to my dp i just wanna use the clamps it came wit im wondering for u guys out there wit this same setup that have the dump pipe or staright pipe how did u guys do ur setup ? thanx for any input or advice or tips i just wanna do it right and simple the first time just be able to remove the cat and dump as fast as possible thanx again
Hey...The idea of the test pipe/dump is to eliminate the cat. The cat has to be removed, and then if you need it for smog, you gotta climb back in there and replace the test pipe...I personally bought a new 3" free flow cat from summit, made it to fit the exact same way the dump fits, and when smog comes up, all i got is 8 bolts and it is an easy swap. Good luck, HTH's!
John
