I just noticed the antenna was up.. tell Melissa to turn of the radio next time and it will go faster
Grumpy,
What was all the times on the time slip?
I tried to give Dan and Russ a relay in BG.. They refused it and said it would slow them down... go figure..lol
anyone video the run??
Because it's a street car and street cars don't run slicks
Grumpy runs so fast because he has indexed & cut spark plugs.
He also has the brakes set up for "no drag" when the brake pedal is released.
The wheel alignment is also set with the front of the car up in the air like its going down the track. Toe-in with the nose of the car up is just dragging the tires down the track.
The headers have been drilled out on the bottom side so they can be ported where they are welded to the "log" and then re-welded back up with a plug.
The front wheel bearings have been loosened to eliminate drag.
The rear end carrier and pinion bearings been loosened so they don't have any "drag" on them also.
EVERYTHING that flows air has been ported and gasket matched PERFECT for maximum airflow.
I run 28 x 9 MT ET Drags on the street all the time. In fact, they've been on all summer
What size MAP sensor is on the car? 5 bar?
Grumpy,
I must have hit the nail on the head with my last post since you haven't denied anything on my list as being not done to Melissa's car.
Nice effort Grumpy...40# of boost takes some stones : ) Think there is any left in it?
nope
nope
nope
nope..plain ol stockers are doin fine
couldn't be bothered
we took off the turbo line so we could get MORE !!! who needs a MAP sensor
Why are you so reluctant to post how much boost you guys were running?
