ok lots were asking about this so here ya go .. If ya want to build it's TWIN call Russ Merritt and he can do his "thing" and build and tune you one
Engine
RJC girdle
ARP hardware
109 stock block
Diamond .020 pistons
stock crank cut 20/20
stock rods
SFI balancer and flexplate from Mike@Full Throttle
212/212 Comp roller cam
Champion STEEL ported heads
Cometic Headgaskets (NO they don't leak )
Champion ported stock intake
RJC power plate
stock plenum
stock TB bored to 62mm
stock crappy factory headers and crossover
3" down pipe to a dual 3" exhaust (we run threw the exhaust)
Dequick V4 stock location intercooler
67 DBB Precision Turbo
RJC boost valve
60# inj
Russ Merritt plug wires
stock ign and coil pack from G
single pump in tank / hot wire
ALKY DUAL NOZZLE set up from Julio
200R4
Russ Merrit trans with Bruce's billet "stuff" .. PTS 9/11 converter from Bruce @ PTS . Bruce sent it to me because I am such a nice guy . this converter ROCKS !!!! Worked awesome !! Thanks Bruce and Russ
stock rear end w c/clip eliminators (remember we are only running drag radials) Moser axles and a TA rear cover.
UMI stock replacement rear control arms
ATR rear sway bar
Koni rear shocks
reg old front tires
MT drag radials
A GREAT DRIVER
Russ Merritt & Me ....GREAT SLAVES
I think thats about it...oh wait .. a Boost and oil pressure guage.. Tack.. and of coarse a SCANMASTER .. Greatest thing Bob and Mike came out with years ago
oh ..goin to weigh the car today ..
87 GN , PW,PL,PS,PA,AC. weight savings .. replaced the steel bumper supports with alum ones from one of my "T"s .. Weld wheels. Oh have a cage in it to so that will add a little .. ok so here is all the secrets :biggrin:
Engine
RJC girdle
ARP hardware
109 stock block
stock rods
RJC power plate
stock plenum
RJC boost valve
60# inj
200R4
ATR rear sway bar
Koni rear shocks
reg old front tires
MT drag radials
A GREAT DRIVER
