Memphis area modified ecm
tysongross
Mississippi Mayhem
Does anyone have a modified ecm in the memphis area that I can borrow/test I think mine has a problem with one of the injector drivers. I can pay you for the trouble. Thanks
if you are only going to run the engine at light throttle, you can test with a stock ECM. It will be a bit richer at idle due, but you may be able to determine your issue.
Bob
Ok thanks bob. I may try that somethings not right trying to narrow it down now...
