Metco lower control arms w brackets $150 pick up only
Too far for me to drive; but here's your pictures.
will they fit stock sway bar and bolt up do you need different hardware or will stock stuff work
I dont think the stock swaybar will bolt up the only hardware not included are the bolts that attach the control arms to the car ones for the brackets are included
You may need new hardware; but I think the stock sway bar will work. The holes are shifted to make up for the new angle.
Check with Metco on Monday.
Metco Motorsports
109 North Park Drive
Anderson, SC 29625
(864) 332-5929
Those control arms were not manufactured by Metco - they were contracted by ATR years ago.
They are compatible with the stock sway bar and should work well.
HTH...
Rick
