I have a question about materials compatiblity of methanol and aluminium as i believe methanol eats aluminum. Now i know when the engine is under boost it will mostly vaporise and suck in all the fuel before it has any time to corrode anything. But i was just wondering in certains situations that it could be possible for methanol to just sit around on aluminium engine componets for a while. in my case im sprayaing just after the compressor in a pipe that goes upwards, so any liquid fuel will just go downwards and puddle at the bottom of the compressor, if the engine doesnt suck it all in. Also after a full power run if you were to say shut the engine of immediately- say a blown part, and the car is left for a few days with alcohol in the engine and manifolds. I'm thinking maybe even the heads and pistons could be effected by the methanol.
Do you think their is a possibiltiy for the alumium to corrode? And maybe a way around it without totally removing the methanol would be to run 50%methanol 50 % ethanol. From my experience methanol is a far better fuel in terms of cooling.
