Methanol EFI Turbo set-up
DCI
Any of you guys running a straight methanol EFI set-up on a turbo motor?
If so what kind of EGT's are you maintaining. I am seeing around 1490. The EGO voltage is around 1100. I can change the timing 2 degrees and see a 50 degree drop in the EGT but no change in the EGO voltage. I tend to trust the voltage more than the EGT reading.
What are some of you seeing?
Tom
