Hello I'm new here and you guys seems to know the world on alcohol / water injection.
So I hope you can help me please don't kill me I dont have a buick but a 95M3 with a turbo kit and just recently a Aquamist Water injection kit.
Is Methanol the same thing as Methyl Hydrate. The reason is that they sell Methyl Hydrate here in the local hardware stores and you can buy them in 4L bottles. On the bottle it says you can use it for gas line anti freeze and in you washer fluid.
Also in the washer fulid that they sell here Methyl Alcohol is listed on the containers.
I have been reading your post for the last week and notice that you guys seemd to run a higher mix 70/30 and 80/20 of alcohol/water.
I sent a email to Aquamist and he is telling me to use all water and when the temp is cold I can use no more than 25% alcohol. He only recommends Methanol & Isopropyl alcohol.
Richard from aquamist is saying using alcohol when it is burnt compared to water will increase combustion chamber temp and reduce the effectiveness of water injection ? You guy dont see to have a problem with the high mixes ?
He said no not use any ethanol based alcohol do you know why ?
My car runs well on Sunoco 94 octane gas no detonation on the stock compression of 10.5:1 at 10PSI. I wanted to get the water injection to reduce intake temp in the summer and maybe run another 1 or 2 PSI more boost. I figure the car will not retard timing under boost.
Thanks Mark
Thanks Mark
