I'm looking into getting a modded ecm and was wanting to know if the 83lb seimens would work ok, I will be looking to be running e85 in the future,thanks
Once the ecm is modded with the peak and hold drivers it will handle any of the low impedance injectors, so 55, 72, 83, 96, 120, and all the way up to the 160's (not saying those will idle well, but they will run).
Thanks Carl, I thought so but wanted to double check since I'm geting into new territory and want to run with e85 and I know the 009's just will not cut it.
I have a extra modded ecm that Turbo Bob built. If you need one ? I am going to install a Big stuff or fast. $210.00 shipped if you are interested. Thanks.
