It won't harm anything, but it may not run right. The peak/hold injector drivers will operate the injectors differently, which has the biggest effect at low pulsewidths, like idle and tip in. So you might have things like a tip-in stumble, or idle might be too rich/lean, BLM's will not be right. If you have the ability to change the chip program, then you can tune it out.
