I did a search to find the center to center (PM Pin location to Vacuum Pin location) placement for drilling the PM pedal to use on a vacuum setup but came up with two results, 1" and 1.5". Can someone confirm which is correct, thanks.
Hey im sorry to jump on your theard but can i ask you what setup are you running on yours because i also want to go with vacuum I'm wondering if you have any part numbers for the booster and master?
