Boost231 said:z
plug for a reds double pumper. who would have guessed...
stock car, reds double pumper
9 sec car, reds double pumper
reds double pumper for the win no matter what you have.
Don't forget the Hobbs switch......
SignUp Now!Boost231 said:z
z
Boost231 said:just installed a dw pump on a 99% stock car. car came in with a no start condition. pump would only pressurize the rail to 10 psi sometimes 20. i installed a DW pump. started the car and rail pressure was at 50psi line off. i adjusted the regulator down to 42 line off with no issue. overwhelming issue? i think not.
maybe i should have just installed a reds double pumper... maybe i can talk him into something he doesnt need
It sounds like you're saying that there's no chance of creating a high idle fuel pressure problem when installing one of these higher volume pumps on a turbo Buick. Are you saying that Sakudog,MNwe4, the many people who have posted this problem,Eric Marshal,and the many people who have contacted me for advice on how to lower their fuel pressure are lying?i installed a DW pump. started the car and rail pressure was at 50psi line off. i adjusted the regulator down to 42 line off with no issue. overwhelming issue? i think not.
It's now a topic that you have first hand experience with so you can talk about it with authority. You won't just be repeating something you heard.I just decided to leave the lines alone and see what happens knowing that the possibility did exist that they may work and I'd be done.
I think these two,along with the Aeromotive pump sold at Racetronics,have similar pumping capabilities.maybe the TT340 is just a little stronger than the DW, who knows.
I can say with certainty that the stock return line will be over-powered by the Denso "Supra" fuel pump. I just ran a new return line and now my fuel pressure will go below the 43# it was stuck at before. The vacuum line had absolutely no effect on the pump pressure before the mod. I believe the drilling of the Saginaw fittings to 11/64" would have worked because my hose barb orifice is that size. I ran new -6 line because I plan to go to E85 in the future with the Racetronix setup.
Discount Hydraulic Hose part numbers 9069-06-14, 104-0404C, and 2404-06-04.
Running two 255s inline flows a significantly less amount of fuel than two pumps that have their own pickups,ie a double pumper.Why is everyone so set on having low fuel pressures? Another option would be using the factory lines, run an intank 255 and an inline 255. Activate the inline 255 under boost and keep your fuel pressures high enough to compensate for the smaller oem fuel lines. Keep your fuel pressure below 100 and you'll be fine. Local at our strip runs a set of 80lb injectors well into the 900whp mark on e85 with 68psi base and 92psi under boost. Using -6 fuel line through the factory 3/8" fittings on the OEM fuel rail. ) Using 3 255's. (LS 5.3)
What's that buick plate do-hickey on your intake?![]()
EGR block off plate![]()
For some reason I didn't think the plate went anywhere near there. You're supposed to be my mentor Rick. C'mon, fall in. I hope you are still around come spring. I have a stack of parts, and more are going to be coming. A bunch I will try on my own though. I might ask you to check out what Lyons looks like
The problem with the stock feed line is it limits the potential flow. You won't hurt your engine if the return line isn't big enough. drill all the Saginaw fittings and the sender tubing out to about .280". Voltage will help more than anything.
