Mod's
If I were you I would skip the engine tie down strap and get HR Parts motor mounts.
For most of the rest of your parts contact Jack Cotton he will hook you up. His contact info is in my signature.
Bryan
I have several sets of new tire/wheel combinations and a fresh RPE built 6109 block-Matt 347 680 8642 anytime.
phoneguy- I already purchased the tie down strap, are the mounts better? and most of my stuff I will be purchasing through cotton but if i can some of this stuff used, I would save some money. Plus i just picked up my block today so i need to get that built the way i want it.
49-blues- I already bought a block and what kinds of wheels do you have, any pics?
Update!!!!
Here is the list: PM me if you have any of these parts.
Fuel:
Fast/XFI full fuel system, and laptop or data touch screen logger.
60 Lb Turbo tweak Injectors that work with stock ECM Or F.A.S.T (New)
Walbro Fuel Pump
Accufab Fuel Pressure Regulator
RJC Plate (Plenum)
Exhaust:
3' Down Pipe with dump
3' Exhaust system No cat pref.
Body:
All body bushing's
Gnx Brace
Both Front and Rear Bumper filler's
Windshield
GNX Gauges
Wiper Arm's
Rear End/Wheels:
Long wheel Stud's
Rear End girdle
GNX Wheels or nice weld-lites or light wheels, (Set of 4)
Line Lock setup
Engine:
PTE 6765 or 6776 DBB turbo with .63 a/r and Billet Turbine Wheel, H-cover (4' in and 3'out) or S Cover (3' in and 2.5' out) (New)
TR Water kit and oil kit (Turbo Saver)
AMS boost controler or RJC boost controler
3' Front Mount Intercooler with pipes
Maf Pipe with cone filter and Maf sensor
62-70MM Throttle Body
Also any good machine shop I can send a block to get checked and worked on that is reputal and does good work.
I will update the list both adding and subtracting things when i purchase items.
Guys please help me out and lets work out a deal so I can start my project.
Again just PM or email me direct at Noneed4nos@yahoo.com
Mike
__________________
The mounts are much better but since you already bought it use it. You have alot of other purchases to make just to get it running. Later down the road when you have the money I would get the HR mounts.
Bryan
Yea i know i do alot of parts ha, I just pulled the motor i purchaed the other day apart and ready to send it out. I was going to send it to weber racing, anybody have any feedback on them or someone else reputal for a good price? Let me know
Update!
Fuel:
Walbro Fuel Pump
RJC Plate (Plenum)
Exhaust:
Body:
All body bushing's
Gnx Brace
Windshield
GNX Gauges
Wiper Arm's
Rear End/Wheels:
Long wheel Stud's
Rear End girdle
Line Lock setup
Engine:
Timing chain cover and oil filter adapter (with bolts)
Fly wheel bolts
RJC Engine girdle
All gaskets
Any engine parts or performance upgrades that are new for 86/87 Gn block let me know.
Mike
Update....7/26/09!
Fuel:
Injectors, Any suggestions on what size let me know.
Walbro Fuel Pump
RJC Plate (Plenum)
Exhaust:
Body:
All body bushing's
Gnx Brace
Windshield
Wiper Arm's
Interior:
Healinder
All seat recoverings
Carpet
Rear View Mirror
Chrome strip that is 1/4'in thick that goes across the dash board above the a/c controls and glove box.
Dash board cover plate
Gnx Gauges
Radio Delete Plate
Steering wheel
Rear End/Wheels:
Rear End girdle
Line Lock setup
Engine:
Fly wheel bolts
RJC Engine girdle
All gaskets
PTE 6765 or 6776 DBB turbo with .63 a/r and Billet Turbine Wheel, S or E Cover, I need 3' Inlet, and 2.5' Outlet. (New)
Mike
I have used 55lb injectors (not very old) and a new Walbro pump still in box. $250 for both. Let me know. I have some chips too if you do not go the XFI route.
