Just remember that the ride height is measured at the rocker pannels behind the front wheels and in front of the rear wheels. Stock with stock tires and wheels it should be between 9 & 1/8" and 10 & 5/8". Make sure to allow for different tire/wheel combos once you measure everything.
Measurements are measurements either way. I believe most of this thread is ground to the arch of the wheel well so there is no sense in changing it now. The only true measrement would be bottom of frame to the ground so we could eliminate any body bushings, shims, etc.
