Shouldnt raise the car at all. Either they put the wrong springs in the box or something isnt installed correctly. they were new in the box unopened. Did you remove the swaybar while you were installing these springs? no Is it re-installed upside down? how can i tell? Did you bind the control arm bolts by overtightening them? dont think so? Is the spring seated in the perch up top? yes Is the spring clocked into the notch in the lower control arm? Did you lube the control arm bushings and swaybar bushings while you were down there? no
