87we410877
- Apr 5, 2005
Ok, so im going with the -8 feed and was told that anything less than a -6 return and you will not be able to lower your FP below 50 psi. So, i took off my fuel rail and it doesnt matter if i put a 2" line on the return, the FPR outlet is only 3/8" and inside the FPR looks slightly bigger then a pin hole. Is there some aftermarket FPR that i should be running for a -6 line? Anyone else done this and run into the same situation? Thanks.
