SignUp Now!Yeah, you need an adj. regulator or you can do what another member said and crush it.
Ok guys new adjust FPR is In.. 43lbs at idle line off. Still getting the same knock. Is 16# of boost to much for 93?
Where are your O2s? You probably need to add a little fuel. If your O2s are good, take a little timing out.
I had to add 5% fuel to get rid of knock at 16-17lb with straight 93 octane.
