More parts MSD RPM activated switch
re-evaluating
Can't even re-member
MSD RPM activated switch PN# 9850 that are converted to work with turbo 6 ignition (you have to send them in to be converted) I have 3.
Selector switches PN# 8670 which is 3000 to 5200 and PN# 8671 4600 to 6800 RPM
These can be used to turn on shift lights or extra injectors or anything you need to turn on by RPM.
blue console gauge pod with VDO water temp and oil pressure no senders $75 shipped
blue pillar pod with boost gauge $40 shipped
Egt gauge has no light bulb no sensor
Comp cams 981 valve springs with some shims new (were installed never run) $50 shipped
daveunderpressure at gmail.com or 330-351-5956
mounts
odell4o8 said:
dave, you got any HR motor mounts for stage engine? oc,
Nope they are several weeks out right now.. How bad do you need a set maybe I can light a fire under Paul... :biggrin:
Dave, no hurry i just wanted to try a pair next time i pull the engine, with my luck that could be anytime that i go to the track, thanks,
