Guys, I have a question. I'm just wondering and looking for a little feedback. I'm already thinking about changing my turbo and injectors.
Basically, would I gain significantly more power by adding a 76mm or maybe 88mm turbo along w/adding 160lbs injectors and retuning the F.A.S.T. My converter really seems to wakeup around the 4000 rpm range, so I think I'm O.K. with the current stall. It really seems to take off aggressively at around 4200 rpms, but still drives great on the street when I lock up the converter.
So, will a 76 or 88 Turbo and 160 Injectors give me a little more power? If so, which size turbo would you guys go with?
If anyone thinks I'm crazy just hollow, because I'm already ready to make the changes. I know Bill, you're saying damn Tony, you're not even letting the current setup break itself in. You know me man, I'm already looking for more power without pulling the motor. Or any other suggestions without going Stage II? I basically want to max out my Stage I.
Let me know what you guys think.
flip
flip
