More Powerlogger Windows 8 install issues.
And to add, RIGHT click any graph and a complete list of other things you can change that graph to playback. LEFT click in a graph to initiate the cursor, and you can as Bob said, use the right and left arrows to move through. And if the file is long there is a slider bar between graphs one and two to move to parts of the log that are further away.
Any other questions don't hesitate to ask! If Bob is busy, I'll try and help.
Thanks guys. How about a quick idea as to how (I know everyone is different) you set up your screens. What data do you set the 4 graphs to and what data do you consider the most important to look at after a run? Just looking for a starting point. Thanks
Its hard to watch the laptop and drive at the same time.. :)
when reviewing a run it depends on if I'm tuning driveability or WOT. But wideband AFR (or O2), knock, boost, to start with.
Bob
Agreed! I'm mostly tuning for driveability now days, so I keep the graph screen active with AFR (wideband), AFRcorrection, Boost,TPS.
But when doing a playback it doesn't really matter what you display because it's so easy to change what you're looking at.
