rearveiw85
- Mar 10, 2009
ARE THERE ANY OTHER TURBOS YOU CAN PUT ON A 85 OR IS THE TA33 THE ONLY ONE?
SignUp Now!I bought a used TA49 and cut the stock O-ringed adapter and welded it to the outlet of the 49. I had to clock the turbo and get a throttle body adapter from turbo6x2 but it was definitely much cheaper than a TA33 would have been. You can do this to almost any TA series turbo which are for sale pretty often on the board.
this might have worked for you back in the day. now almost all the turbos come with a dynamic seal. you put a dynamic seal turbo on a hotair and it will be blowing so much oil through the turbo it wont even be funny. its not as easy as it use to be. you cant just welded the adapter on a TA series turbo anymore you need to have a carbon seal and backing plate.
