I thought id try to sell this local first.
This is a Moser 12 bolt setup for G body cars with Eaton posi with #800 lbs springs,carbon fiber cluches, large ford axle bearings,large ford backing plates,3.42 gears,33 spilne axles,girdled rear cover,4 3/4 bolt pattern,long hardend wheel studs,setup for coil over or stock springs,Moser yoke..This unit has 10 to 15 passes on it and is like new inside.New it was $2750.00 and i will take $2000,00 obo.
Here is a link to Moser and with the upgrades you can see what it costs new..
Moser Engineering
I also have a set of 12" wide centerline wheels for this with used slicks
Moser Engineering
