Moser Axles!!
Crazi
Why Try...
Just got my axles from GearAreUs. I ordered the longer 3" studs and need new nuts but the thing is, they pressed them in for me! :D :D
I don't know if that is normal but I thought it was really nice. Just wanted give them some brownie points. ;)
I have the same axles and studs. My studs were screw in, and also drilled for press in stock studs. Did they change from screw in to press in? Anyway i like mine and as for lugnuts, i got some long turck lugnuts and cut the end off. Works for me.
Mitch
I don't know.:confused:
They were in when I got them and they "look" pressed in. Do screw in studs look like they screw in once they are screwed in?:confused: Meaning after installation, can you tell what type u have? Anyway, I got some open end lugnuts from Autozone for $0.99 a piece. Won't get to install them till this weekend though.
