Most power with stock motor
highboostgn
What's the most power/ quickest 1/4 that anyone has recorded with a stock motor(only using bolt on upgrades ie turbo, piping, upgraded FMIC,Exhaust, Alky, 200r4,Th400, converter,chip, injectors. You get the idea lol
Low 11's high 10's....but I have only been 11.80's@26psi pump gas/alky. This is a safe tune. The passes were 11.84 and 11.83. Nice to make passes without worrying about being on the ragged edge. I'm sure the car will go faster but my time is limited since the year is coming to a close in Chicago. Cracking stock pistons will end your day on a sad note. I say if you want to go faster than 11.50, build a good long block.
Had my last Gnx clone solid 11.50 car 25lbs boost
timing chain replaced and bolt on's!!!
JD
jdsgnx said:
what happened didn't see ya in B/G????
My PTO is depleted for the year and they shafted us out of vacation time. I was supposed to earn a week october 1st but they changed it
So that anyone that was earning a week from september on doesn't get it till January. Wish I was there though. Congrats on yr pass. That combo is proving to be very reliable the way you are running it.
I've been pounding my stock internals at 11.50'ish for at least 200 passes now and 30k street miles. I drove 600 miles to BG and went 11.343 on the last day. I'm working on a different motor now but I don't worry about my stock block as long as I keep the TE44 on it. I let it make as much boost as it can :D.
I was hoping to see you there too. Nice to put a face to a screen name every once in a while. Thanks for all your help. Sorry about the pto situation.
