Motor knock
gottav6
sorry for such a small question but what is motor knock and how do u get rid of it...? thanks
There are 2 types of knock and both are totally unrelated.I am not sure which one you mean so I will cover both.
1.Rod Knock-piston rods bearings have excessive clearance and therefore make loud horrible sounds referred to as "knocking".Solution:Rebuild the engine
2.Detonation,pre-ignition,spark knock-(all the same thing)In the case of our cars is a result of not enough fuel or octane or too much boost or even too much timing.Solution:Race gas,lower boost,fuel system uprades,alchy,new chip suited to combo and others are all effective methods.
Actually, they are related...It just takes a while...If #2 keeps happening, #1 will be the result...
