Im a little confused with this problem. The TTA is almost ready to hit the streets but then i found this.
While trying to spool up the turbo while on the foot brake, and ebrake the check engine light comes on ad the motor quits. This occurs every time , at about 2000 Rpm. If I manupulate the throttle i can keep the car running.
I did a quick once over of the battery cables but have yet to check grounds. I did not dis assemble the cables or remove the wire loom . I know this is common with the Regals.I also have not checked for codes due to the extender chip-SM update.
Are these common issues with the TTA. The car is stock with only new valve springs , 340 FP, and fresh blue top injectors, SM and KN filter. The car also has a MAF T, 3.5 MAF and Extender chip.
