Movement in neutral or park?
Nasty
empty wallet
If the trans is in park or neutral, and you goose the engine a bit the vehicle seems to almost surge a little. It does not actually move forward, just you get a little forward surge-kinda like if you had it in gear and power braked it a little(but its very minor, sometimes not even there). Only other oddity is it shifts very hard, it seems clunky if your driving in slow traffic with lots of up/down shifting between 25-40 mph. The hard shifting was like that before the rebuild too.
Opinions appreciated.
If there is a lot of drag on the forward clutches you may get some movement even though the clutch is not engaged.
