(MOVING SALE) Everything needs to go!!!!! stock and Performance 86-87 GN
________________________________________
I accept Paypal or MO.
Paypal: gymboree4mygirls@aol.com
Parts are located in CT
Pictures Here: TurboZV6 - Photobucket - Video and Image Hosting
Shipping included on most item only to the upper 48 States. All others will need to add shipping.
Adjustable FP regulator $80 shipped
Grand National Header panel $200 shipped NEW IN BOX (from Danko Reproductions) has a small crack or something on pass side top near hood line
GN Long Block needs rebuild $550 Local pick-up only
8.5 posi rear complete drum to drum w/S10 pistons $740 Local pick-up only
Stretch Stock Location IC w/hoses, clamps, shroud, up-pipe. $500 shipped
50 lb injectors w/chip $220 shipped
86-87 Throttle body complete $90 shipped
86-87 Fuel rail $35 shipped
86-87 Stock Injectors $50 shipped
86-87 Turbo bracket $45 shipped
blackout marker light $35 shipped for passenger side
Blackout wheel well trim $50 each piece (both rear and pass. Front)
87 GN Grey lower door panels $120 shipped
GN Console with shifter and T handle $190 shipped
Radiator hold down(plate on top that hold radiator and electric fan) $50 shipped (2 avail)
Shifter with T handle $55 shipped
Fuel sender/fuel hanger(analog gauge) $100 shipped
ENGINE PARTS:
AC lines(86-87) $40 (2 avail)
Air Cleaner assembly(86-87) $25
Alt.(86-87) $70 shipped
Balancer(Turbo harmonic balancer) $85 shipped
Battery cable guide(Small plastic guide that holds the positive battery cable to the lower front cover) $20 shipped
Chip(stock 87 chip) $30 shipped
Elbow(84-87 Turbo elbow) $25 shipped
Fuel rail(86-87) $35 shipped
Headers(factory Exhaust headers, both sides & crossover) $150
Heads(stock 8445 heads needing rebuild) $50 a set
Intercooler $50 (2 avail)
Intercooler shroud $30 (2 avail)
Intercooler brackets both for $50 (2 sets avail)
Main accessory bracket(86-87,the big alum. one) $80 shipped(2 avail)
Motor mounts(metal, frame mounts) $35 shipped
Power steering pump(86-87) $70 shipped (2 avail)
Pulley(86-87 Crank pulley with adapter) $35 shipped(2 avail)
Pulley(86-87 Water pump pulley) $25 shipped (2 avail)
Throttle cable(86-87 Throttle cable) $30 shipped
Stock Valve covers $35 shipped
INTERIOR:
Arm Rests( grey arm rests) $25 for 2 shipped
Console shifter plate(Plate on console that goes around the shifter)$30 shipped
Console (87 GN) $150 (2 avail)
Shifter $35(84-87 GN, no T handle)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light $20 shipped
Body Parts:
Blackout(Front windshield blackout trim(3) ) $40
Bumper(GN Rear black bumper) $70 prefer local pickup
Front bumper Impact cushion (looks new, no scratches) $70
Rear fillers are still flexible, will need paint. passenger side had a small nick in it where the bumper was rubbing. Check out the pics. $140 shipped
Front bumper Impact cushion (look like replacement one with white line good condition) $50
GN Black headlight retainer ring set (4 pieces in GM packaging) $50
Stock steel hood gas shocks (no leaks, keeps hood up) $30pr shipped
GM signal lamps (new in box LH and RH) $68pr shipped
Tail lights with blackout trim $90 pr
Mirror (Passenger Mirror w/remote) $35 shipped
Wheel well (Turbo plastic wheel well pass side) $80
Passenger headlight bezel (Brand NEW GM) - BO
NOS Passenger corner light - BO
Passenger head light bezel w/corner turn lense (Look Perfect, Newer) - BO
NEW GM Drivers side outside window weather strip (black) $70
Other Parts:
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $100
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
windshield wiper assembly $15
Brake dust shields $15
Also for sale:
2000 Saleen Mustang S281
#762 or 974
White w/white rims, only 2,2xx miles. Showroom condition. Always garaged. non-supercharged
Asking $24,700 obo
ENGINE PARTS:
INTERIOR:
Body Parts:
Other Parts:
Also for sale:
#762 or 974
Asking $24,700 obo
