Mr. Licht....Full Throttle
notacarlo
eggs are liquid chicken
First off, thanks for the fast shipping. I think when I hung the phone up the doorbell rang.
Anyhow, I re-purchased a MAFtranslator and 3.5" sensor. I use your Extender Extreme for 60# injectors. I reinstalled everything and I now get a strange symptom.
When I roll into the throttle (from under hood) it will rev to no end. If I snap the throttle it will completely cut out and return to idle when I let go of the linkage. If I do it right in the middle it will cut out and rev, cut out and rev.....etc.
Fuel pressure is set at 44 psi static. I tested the TPS and I get correct voltage through its range of motion.
Am I missing anyting else?
Thanks,
Dan
ps. any of you other guru's feel free to chime in.
I forgot to add the dips are set at all on for the EExtreme. No change on the base and wot settings. Plugs look good, gapped at .035.
Never mind, It is the 3.5" MAF that is faulty. Another quality GM part.
Yep, I slapped one of the 6 stock ones I have on and no problem.
No matter what, when you purchase something brand new, you just don't expect it not to work. Then again I look at all of the parts I have bought over the years and at least a quarter of'em had issues.
Of course not Full Throttles' fault. I could have gone to GM direct and had the same issue.
