John Purdom
BLACK SABBATH
- Aug 12, 2002
Has anyone used the M/T drag radial in the 275/55/16 size on an 8" rim?
SignUp Now!turbosam6 said:Thats not an existing size, are you talking about a 275/50/15 or 255/50/16?
I ran a 275/50/15 on an 8" rim, it fits but a 10" rim is much better, makes the contact patch bigger.
pacecarta said:well not to be an ass but you asked in opening post for opinion on M/T drag radials now you try to call poster ignorant because your talking M&H racemasters ,![]()
i run MT 255/50 16 on an 8in rim and in my opinion thats as large as you want to run on an 8 in rim . the MT Drs hook better than any tire ive tried and better than the et streets both in hook and overall handling
i wish MT made the 16" tire in a something other than the 25 3/4 that they do
if you want to run 275/50s they will fit if youve got a 4in BS and airbags to keep the wheel lips up , but dont count on any better grip unless you go to a larger rim
2QUIK6 said:Hey John, you finally get the car back on the road?
I'd think that size should fit fine as long as the backspacing is no more than 4.25" and no less than 3.75"
I have 275/50's on 8.5" wide rims now with 3.75 BS, plenty of clearance, but that same size tire on the stock 7" rims with 4" BS they would rub slightly. Of course this is with 15" diameter rims in both cases but I don't think that matters much.
Hey if your out and about Sat the 30th, the Lake Worth Boat and Ski club is having a car show, I'll have my fleet out there.
Bring the car out to Redline Aug 13 for the Buick club race.
Hey Mike, the gates open at Redline at 6pm and open time trials are till about 9pm then elimations start. Usually ends around 11:30pm depending on the # of cars. Now the track is open to all cars so you can stay till close and watch all the other action.Mike70gtx said:If things work out in August, I'd like to come down to Redline and try the Buick thing. It's a solid two hour drive for me and if something breaks I might have a little hard time getting back. What time do things start and about when do they get over?
My bad, the next event is Aug 13th...not the 9th.2QUIK6 said:your welcome to come and hang out, we usually have about 12-15 TRs there. Next event is Aug 9th.
www.lspbc.org
John Purdom said:Well, I'm looking at M&H Racemaster drag radials 275/55/16 at Summit here:
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=0+314173&autoview=sku
Perhaps that's a new size you weren't aware of. I want them because they're 28" tall. No chance of hooking w/a 26" tire.
I would like to retain my rims for the street, as I've got Enki GNX style 16x 8" street wheels, and would like to keep my 15's for the ET Drags. This car only gets taken out on the street to have fun, so I'm not concerned with milage. I just need something that will come close to hooking on the street. I burnt a set of regular ET Streets up in less than 100 miles.....
