MT DRs
vacuum 6
Just installed another set of 275/50/15 but now with R2 technology...simply amazing tires.
Have you tried them on a drag strip? I have yet to try those. I'm currently running the MT radial pro which I like. However I will be going back to the ET Street SS.
I'll try them soon. On the street hooks great when I walk into it.
I'm gonna try dropping tire psi to 15 and unhook front sway bar and see if I can get 1.60...maybe a high 1.5
I just jumped up to the 295 on 10" wide aluminum rims. It's taller than the 255 also. I hope it doesn't slow me down.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I run 15-17 psi cold on old style mt dr's best 60 is 1.55 with 275/50/15 te60 loose converter
Air lift air bags metco adj upper reg lower Morosso trick rear coils cheap lake wood 50/50 rears 90/10 front shocks
Interested to see the new compound results. I opted for some M/T pro bracket radials for my other set of tires, and still have the old M/T 275/60 DR on my street wheels. 1.46 on the old style DR at 17 psi here.
