How fast are you in the 1/4 mile mph and at what rpm are you crossing the finish line? I've gone 125 mph in the 1/4 on both heights. If you are going to go faster than 125 probably get the taller tire. New bushings won't change how the body sits on the frame so it may rub the fender well or exhaust tips on the taller tire even if it doesn't rub the frame. The taller 275 60 typically is narrower mounted on the tire than a 50 series. Mileage may vary and the same tire that fits on one car may not fit on the other, as my 28x9 MT Et drags on T wheels and 275 50 17x8 DR's fit my GN perfectly but both require 1/2 inch spacers to fit on my T.
