SignUp Now!You guys do realize that there are actual "muffler" bearings on some cars, right? The Viper had a mearing assembly in it to opne the muffler up so it was a straight shot through. Some I/O boats also use what's called a muffler bearing on them to keep water out when the engine isn't running.![]()
PASSENGER SIDE FIRED?!? Ah hell...When mine went out it the late 90's i installed dual overhead muffler bearings, just make sure you install the passenger side first so you dont over-torque the cv joint inside the 02 sensor bung... i found that using the lefthand #2 phillips was okay but what really worked was when i just used a torx head and jammed it in there real tight.
Its funny you should mention that. I was given an irwin crescent wrench as a door prize and it was one that instead of a roller in it there were teeth to set specific sizes. That bitch was metric and would NOT work on standard bolts.Make sure you use a metric crescent wrench for the install
www.kalecoauto.com has some replacement muffler bearings. Also alot of other hard to find parts, such as an adjustable power band and cross drilled brake lines.
I personally like the piston return spring - http://kalecoauto.com/index.php?main_page=product_info&cPath=12&products_id=49
