SignUp Now!It sounds like you got an off the shelf, fits all HP 200-4R with no consideration for the cars existing wiring. Which means to me that the calibration is going to be suspect as was mentioned earlier by someone else. It is not good to rush into buying a transmission with these cars. Good luck.
I have no ware to keep the old core, I just cleaned up all the old parts and junk I had laying around.
Yea.... GM is still cranking the trannys out....... NOT.....BRF cores are cheap and easy to find anyway :redface:
I ended up buying a trans end TCC connector from Caspers and installing it. I also bought a TCC solenoid from Kerbans, but that did not fit properly, so I left the TCC that came with the trans and changed the trans side connector. I have not test driven it yet, but did get a nice Dextron 3 shampoo.
Was the new TCC longer? A lot of replacement TCC solenoids are for a 700 which are longer. To use in a 200, there are a pair of stand offs that are usually supplied with the TCC solenoid to use when putting it in a 200.The new TCC solenoid didn't fit? Bad sign. Next time you're in the pan, take some pics and post them.
