Turbo-Archie
 - Oct 8, 2002
I thought you were going to post pictures?
SignUp Now!I don't think I would say that. There really is no replacement for displacement
Come on out to the drag strip and prove it.
Then why do you run a stroker?
"Lou Czarnota Built 109 Block Stroker Motor"
Off topic question here:
Is there a MAJOR difference in performance between a 231ci and 247ci stroker LC2?
Strokers are thousands more than a 231ci setup, but is the performance from the extra 16ci (7% more ci than stock) that profound, beyond saying "I have a stroker"?
Maximum power potential is only the 7% more if that. The larger gain is with the stroker is more TQ and the ability to spool faster.
This could allow you to go with a bigger turbine wheel and potentially pick up top end hp.
OK.
Are there any dyno sheets comparing the 2 to show HOW MUCH more TQ or top end HP is produced at a certain RPM vs a 231ci motor?
im waiting to see them as well. really, I am.I thought you were going to post pictures?
