Before I start welding, wanted your opinions on this. I have to move my crossover pipe to cross in the front of the engine. I am using 2.25" 16 Awg mild steel mandrel bent pipes. I plan to have the slip fitting with a clamp on the joint just below the oil pan and use the v-groove clamps to attach it to the headers. Does anyone see any issues with the way I am doing this?
Also, I have never welded tubes to header flanges before, I plan to weld it from the inside around the perimeter then grind it smooth around the inside, then have the header flange machined flat. Any suggestions or tips doing this would also be appreciated.
Thanks,
Matt
Thanks,
Matt
