my gn is breaking up in high rpm at 20psi
SHOULD I GET THE CHIP WITH OR WITH OUT THE STUDDER I ASK BECUASE I HAVE A 2800 STALL CONVERTER AND WILL I BE ABLE TO BUILD ENOUGH BOOST IF THE ENGINE STUDDERS AT 2300 RPM
I don't know what this studder is... I'd say no if it's a rev limiter... Maybe Thrasher could make a recommendation if nobody else can..
I just helped my friend put 40's in his car the other day. His stockers were all cracked up and Chuck Leeper hooked us up in a huge way. His car flat out rocks now! I picked up a Joe Lubrant 26º for good race gas and have a Jay Carter 93 octane chip on the way for street duty. Both chips were $50.00 and I suggest you have one for race and one for street like here. The 40's by own their own go mid 11's so with the right chip you should be golden. Hard to tell what you are running with the 40's right now. Since Joe isn't around to do them now I would get Brutal 40 lb. chip setup. BTW-I don't think you need a studder :D
