Cool. My up pipe was blowing off too. It was due to the lubricant in the alky injection system (older non progressive SMC type) blowing out around the hoses and then "soaping" the pipe up. It was also a 3" chrome pipe with not much of a lip like the stock up pipe. So I cleaned it all up and my bro welded a fatter lip on the up pipe. Never came off again.
Yea, a lip needs to be welded around my throttle body. This is the real reason why the hose won't stay on but these brackets have proven to be THE sure way to keep it on. Under high boost the up-pipe tries to pull away from the throttle body but with this system it can't move back at all. I've proven that to myself since this is the ONLY thing that I have changed and it has already stayed on at 31psi of boost.
With these brackets in place I don't need to worry if the clamps are on "100% perfectly", or if I got all the oil off the surface of the hose and TB, or .. ??? These brackets keep the up-pipe from pulling away from the TB and that is why the hose stays on at these boost levels.
I've modified the assembly a tad from the photo above but if you can see it now the hose has a slight wrinkle in it b/c I pulled the hose onto the TB a bit so it's not under any tension at rest. The pipe probably still moves around a little and I don't want it pulling on the hose at all otherwise it may loosen it at the throttle body. Under boost I'm sure it expands like a ballon so the wrinkle isn't causing any distribution issues.
I'm very confident that this will help keep my new hoodliner from being blown apart!
KS
