2. The wear pattern is right in the middle on all bearings. More prominent on the bottom side of bearing.Cam bent?
1. Need to put it in a lathe and check for run out.
2. Cam brgs are in crooked? What do the wear patterns look like?
3. Time to start fresh....
3. Never!!!!!!
I probably will end up replacing everything in the end but I will try to make it work first. I will spend countless hours and $$$ for no reason other than me being stubborn.
