After around 20 hours of porting I managed to "finish" my heads. I did a lot of experimentation with a home made flow bench and I just got tired of going back and forth.
In the end I ended up doing the only two things that actually made a measurable improvement on my bench.
I opened up the valve throat to 90% of the valve diameter, then blended it in and blended the short side radius.
I also removed as much material as I could from the biased side of the valve guide boss. I then "swirled" it around the back side of the guide. Just doing those two things and NOTHING else made a massive improvement in airflow.
I have extra heads and I tried flowing a port done up to look like what you would think would flow a lot, and that actually flowed substantially less than the port I did that looks like these pictures.
FYI surface texture means pretty much NOTHING to airflow. So all those picts that people go ga-ga over because the porting is a smooth CNC finish. That doesn't mean anything to airflow. The shape of the port is everything.
I also learned some interesting things that I might apply to future heads. Playing with clay I found that adding a large hump of clay on top of the short side curve increased airflow a lot. It also changes the sound of the port. You can hear a "smooth" flowing port vs one with turbulent airflow. It's kind of interesting to note that the port with the clay in it sounded very smooth.
One thing I added to these heads that I wasn't able to test is the tapered head bolt pinch point. I removed as much as I could from the top of the port and tapered it down to where nothing was removed at the bottom. Much of my research online has shown that this seems to be the way to go, and it kind of makes sense to me since I'd like to keep air up off the floor of the port.
These heads still need a valve job, and will probably get new exhaust seats at a minimum.
Speaking of exhaust, I couldn't open the exhaust throats up to 90% because seat is very wide and thus the bottom edge of the seat would be damaged if I went to 90%. I just opened them up to essentially the bottom edge of the cut. We'll see how it all looks with pressed in seats installed.
I also did a fair amount of chamber work. I'll let the photos do the talking.
Sorry for the photo quality. These are cell-phone picts. My digital camera does not want to work today for some reason.
Any comments/questions would be appreciated.
intake bowl
exhaust bowl
Polished chambers
This is a picture of the head sitting on the block. The chamber in the head is larger than the bore on the outside edge of the intake valve. This can't be good for airflow. Luckily, its in an area where there isn't a ton of airflow relatively speaking. I found this out by spraying some easy off through my bench and seeing where the easy off left a stain in my fake cyl bore. I'm still contemplating notching the top of the cylinder bore.
Here you can see how I only removed material from the top and just tapered it down at the pinch point. The picture doesn't really show it well.
intake bowl
exhaust bowl
Polished chambers
