my project,but long time coming
turbo 250
trying to upload pics
what do you think about rebuild and info i need to do before installing part
more pics
some more coming
i got to say thanks
cal & holly hartline
jack cotton team
bryan at gbodypart
full throttle speed
rjc racing
hR parts n stuff
ta performance
bobby at rpe racing
tom at champion cylinder heads
akly control
gn1 performance
and still buying
three more
long way to go but trying to focus
Looks great!! Thank you for your buisness! Give me a call before you fire it up and we will dial in the XFI.
some update pics
here is pic of radiator support,front wheel spindles,rearend,engine on frame and innercooler,radiator mounted .all parts was powder coated
frame was sand blasted and then powder coated too.best money spent.
that's the only upgrade i wish i would have done. but my frame was not bad it only had 23,000 thousand miles.but your's looks real nice keep up the good work
body pic
here are some body pics
I hope he didn't run out of money, those pics sure did look expensive. My mouth was watering. would def. like to see how the progress is coming.
up date on project
transmission cooler,slotted rotors,inner/outer tie rod ends,wilwood rear brake kit,adjustable proportioning valve and adjustable kyb shocks
update got my new wheels and tires
some times it takes alot of patience to get things done right,but you would thing if you are paying some one good money to do body work it would get done....
