My sons 00 Regal changed to E85 with Dyno results
fast86gn
Texas Moderator
Staff member
He had already put down 286whp on 93 pump, he upped the injectors from 42.5's to 65's. Retuned the car up the timing to 22 degrees. See the chart below
We are expecting low 12's in the 1/4.
He ran a 12.80 @ 107mph on a 2.8 pulley on pump and 19degrees of timing.
He is now on a 2.7 pulley on E85. Running about 14lbs of boost and 22degrees of timing
VS cam, LS springs, Headers, 3inch DP, full exhaust, IC, 103 plugs, 180 stat, DW300 pump hotwired, N* throttle body.
I'm consistently getting 1.80's on the MT's on my silver Regal. His 1.85 were on Nittos.
Hey David too bad the pictures aren't up here. You mentioned to me what was done to the transmission and who built it, could you remind me of that information again>
