My Turbo 6.0 LY6 4l80e build
Thanks fellas! Tuner came by and I got her cranked up and front end on...!!! She's got oil pressure!! Pics and vid soon!!
What rear seats are in there?
How did the linkage brackets work out from the 200R4?
I bent the bracket back a touch and was able to get away with it. I used the B&M cable and opened up the the gear selector a little bit. you will need the stock bracket on 2004r transmission then fab up a small L bracket to work with the cable nut on the trans end of the B&M cable.
The stock cable will not work as it will be stretched too far. I recently seen Hurst makes a double ended eyelid cable which will probably work even better than the B&M.
Seats are GTO 05-06.
Looks like a well thought out quality project and you have made great progress in that amount of time.
Love this build, I am looking a doing something similar with the Vintage Air, 6.0L/4L80E, and single turbo. May have some questions for you as I begin my build.
Well just measured for the driveshaft, and I need to order a hood soon!
I'm currently in the process of putting the interior in, rear LED light wiring, seat belts... all the little fun stuff!!
Well had a little set back... put the driveshaft in and trans not engaging. Checked lines and pump is not working... Pretty pissed off right now.
