meanchicken
gallo vicioso
- Oct 6, 2007
I dropped my fuel tank, pulled off the old original fuel pump, started to install the Walbro..and it's about 3/4" shorter than the old pump.
The numbers on the walbro (bought from Turbotweak) are:
F20000169
23407-2
The problem it creates is that the OEM piece that the pump plugs into is not long enough to stay securely plugged in between the walbro nipple and the nippe on the sending unit poutlet tube.
Am I supposed to reuse this rather important looking OEM piece, or replace it with the rubber hose that came witht the Walbro?
Tim
