T
t-hill87we4
Guest
What I did:
Bought Thrasher 92 chip w/anti-theft, wasn't thinking about what I was doing, and disconnected connectors to ecm before disconnecting neg. battery lead. After replacing everything, car won't start, just cranks. Same symptoms with stock chip also.
What I've done since:
Checked to ensure that ecm was getting 12v from battery on C16, swapped back to stock chip, can't tell whether fuel pump is running or not (will bleed fuel pressure and see if trying to start car will re-pressurize the system in the morning. It's too late now). Haven't checked for spark yet either. All fuses are good (at least on fuse block. any ecm related fuses elsewhere?)
Have I toasted my ecm, or is there something I'm missing? Any help would be greatly appreciated.
