WTF!
the poll ratio of "yes" versus "no" is actually approaching 50/50. are you guys just playing around or something? I sincerely hope nobody actually *doubts* the plane *WILL* take off!!
you guys who are saying "no, it won't take off" actually have driver's liscenses????
like someone else posted....
THE TREADMILL IS IRRELEVANT!
The treadmill will *NOT* keep the plane stationary. Turbine engine, propeller, rocket engine....doesn't matter. They all develop thrust against the AIR around the plane, *NOT* against the ground or the treadmill. It would not even matter if the treadmill was moving 500 mph in the opposite direction. The plane would still develop forward velocity in relation to a fixed point in the atmosphere at the same rate. The ONLY limiting factor would be wheel bearing or wheel brake friction. If the brakes are released and the wheel bearings are functioning normally, the plane will move forward as usual. PERIOD! The treadmill will just spin the wheels faster, that is all!
Think about it....when you're flying in an airplane in the opposite direction of the earth's rotation (which is approx. 1,070 mph at the equator!), does it matter that the ground below you is moving that fast in the opposite direction? No, because the planes engines are producing thrust against the AIR not the ground below. The same airplane will have an *airspeed* of 300 mph regardless of what the ground (or treadmill) is doing below! It is that *airspeed* not *groundspeed* that gives the airplane lift.
?comprende'?
