Freddie's Buick
Hell No! I'm not a junior
- Jan 3, 2002
My experiment was a success. I've learned a couple of things....and I got a few ideas. Click the link:
http://members.telocity.com/~familiadiaz/Retro.jpg
Here's the recipe:
1) 1979-Chevy V-6 HEI/VAC distributor.
2) 1980 Pontiac Q-Jet Modified. Click the links:
http://members.telocity.com/~familiadiaz/HEI-VAC.jpg
http://members.telocity.com/~familiadiaz/'80 Carb.jpg
I removed the ECM, ECM fuse, ISC, A.I.R. pump w/plumbing and EGR valve. I also made my own E.E.C. Click the link:
http://members.telocity.com/~familiadiaz/EECS.jpg
Pros: A whole lot less spaghetti. (There's actually an engine under there... ). All adjustments are easier and no inteferance from the computer trying to compensate. She's faster now than with the ECM, but I have not had much time to evaluate the totality.
So I will say it's inconclusive. (Besides, I did a boo-boo on the firing order months back and I did'nt even know this till I removed the EST distributor. 1-2-3-4-5-6 instead of 1-6-5-4-3-2 .... ).
What's bizarre is that with the ECM system it never backfired and it ran very good? But when I installed the HEI/VAC.....pop-corn city! Wow!
Cons: Obviously...not as fuel conserving. But enough to concern me. (I've grown used to my previous milage consumption). This I'm still evaluating.
I got an idea also. What if one can keep the Electronic Q-jet and ECM system but bypass the EST? This would result in maintaining the ECM's excellant fuel conserving capablities, yet allow the driver to maintain full throttle and timing advance the old fashioned way....at the pedal.
Here's my idea: Remove the EST/HEI distributor. Next, install a HEI/VAC distributor. On the 4-prong EST connector lead to the ECM connect a wire from the 'C' prong to the 'C-' terminal on a HEI/VAC distributor. On the 'B' prong connect a wire going to the 'TACH' terminal of the distriburor.
If the voltage at the 'TACH' terminal of the HEI/VAC distributor is 5-volts, (I have'nt checked yet), then in theoy this would fool the ECM into thinking that the proper voltage is being recieved for it to control the spark. Click the link:
http://members.telocity.com/~familiadiaz/EST MODULE.jpg
As for the 'lock-up switch' for the THM 350-C Transmission, most forums I posted on agree that no damage may result from not using the 'lock-up' function. But on the highway it's good for cruising. For now I'll just go without it.
Here's the recipe:
