thunderace31
Banned
- Sep 2, 2002
Well I love my Buicks and I sold my old t-type and got a Typhoon I like it its a fun truck but I have decided Id rather have another t-type or GN that runs the same #'s or faster ![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
This ty is #1606 mods are below. It went 11.42 at 116 mph with a crapy 60 foot of 1.94 with a low boost (5psi) launch so there is more in the truck![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Trade value is $15,000 so Im looking for something of like value in a T or GN I do prefer white Turbo t's I dont care if they are t-tops or not Needs to have a good build on the engine and at least a 67mm Ball Bearing turbo and a built trans. Roll Cage is also ok but has to have a full interior as I do have 2 boys to put in the back![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Ill get some more photos tomorrow of the inside and the engine bay
1992 Typhoon #1606
Stock block
Nitride d stock crank
L35 heads
Eagle forged rods
TRW forged pistons
Harland Sharp 1.5/1 roller rockers
Crane Hydraulic Roller Cam
Melling Oil pump
PTE51 turbo w/3" downpipe and cutout - internal wastegate w/new actuator rod
RPM 3" stainless exhaust (I have it dumping out right in front of rear axle)
RPM Dual Electric Fans with Aluminum upper/lower shroud
Edelbrock water pump
A2A front mount intercooler - polished piping/Treadstone performance silicone connectors
Knockoff HKS SSQV blow off valve
Manual boost controller set to 15psi (rock solid)
60# injectors
180 deg thermostat
Jeep steering shaft from board member fivetodrive
Kenne Bell AFPR
Exterior
Repainted in March '09 with Sikkens Arctic White (Corvette white)
Body is in mint shape
Clear corner lenses
HID headlights
Black GMC grill letters
Shaved "escutcheons"
New Gray Typhoon logos (GMC Truck Motorsports on tailgate)
Brand new PPG windshield and molding
New wipers and wiper arms
Rear wiper delete
Roof rack shaved
Morxchn style Gunmetal Z06 wheels w/polished lip (17x9.5 all four corners)
Federal SS595 275/40/17 tires (maybe 300 miles)
All new plastic rivets attaching the cladding
Interior
9 out of 10
Seats are in excellent shape - very little sign of wear
NO cracks in dash whatsoever
Carpeting is perfect
3 gauge pillar pod (Ultimate display, autometer boost/vac, tranny temp) - tranny temp not hooked up
New headliner
Manual fan override switch
Miscellaneous
Camball automotive 16 postion chip 6 street settings and 6 110 octane settings and 4 116 octane settings (Currant setting is # 6 for 110 octane
A/C delete
ABS delete
Cruise control delete
Tranny cooler mounted to core support w/aluminum brackets
Jeg's small radiator catch can mounted where vapor canister used to be
New stock style radiator
built 700R4 tranny - have receipts
Bilstein shocks - installed by previous owner
Belltech 3" drop leaf springs w/1" blocks and pinion correcting wedges (bought from Jags That Run)
Front lowered by turning torsion bars
New power steering pump/pulley
Optima Red top battery
K&N 3" air filter
3" Cobra elbow off the turbo
Completely rebuilt turbo in April 09 (bearings/seals)
Polished Typhoon plate on upper intake
New stock style distributor, ignition module, coil
Just did tune up - new cap, rotor, plugs (NGK UR6 gapped to .28), wires (Taylor 8mm Spiro Pro),
fuel filter
ALDL cable for datalogging
New GM knock sensor
ECM relocated to glove box for easy access
K&N Breather filters on both valve covers - NO PCV
New GM torsion bar mounts
Tons of new hardware throughout the truck
RPM Braided turbo oil drain line with -AN fittings
RPM Brake Booster hose
1992 Typhoon #1606
Stock block
L35 heads
Eagle forged rods
TRW forged pistons
Melling Oil pump
60# injectors
180 deg thermostat
Kenne Bell AFPR
Exterior
Clear corner lenses
HID headlights
Rear wiper delete
Roof rack shaved
Interior
9 out of 10
New headliner
Miscellaneous
A/C delete
ABS delete
K&N 3" air filter
fuel filter
New GM knock sensor
