- May 28, 2001
"The battery voltage also started reading low again." Why not fix this issue B4 looking at the WB/NB problems?
SignUp Now!Does your chip run closed loop above an idle/while cruising?I do have the gauge with the WB, and it agrees with what PL and SM are showing.
I got it all back together and running tonight. It runs okay.
When I first started it, and the chip allowed closed loop idle, the narrowband and the wideband were cycling together just fine. The battery voltage was also reading correctly. I shut it off, and restarted it, and with an open loop idle in park, the narrowband sat at .840, and the wideband sat at 12.8-13.2. The battery voltage also started reading low again.
Tomorrow, I'll hook the laptop up, and take it up on the hwy to see what's going on. I'm also going to hook a multimeter to the O2 input to the ECM, and see if what PL and SM are telling me is true. If it's not, I can only assume that the ECM is junk.
How low? Are you referring to the number you see on the Scanmaster?The battery voltage also started reading low again.
Is there something you did that you think caused this?it does look like the O2 is cycling properly now.
If you select the Dynojet wideband on the configuration screen,your wide band seems to mimic your narowband quite well. Your wideband is not reading correctly.
How does the car feel at full throttle? Your wideband numbers seem to be uniformly off as if it's output voltage is wrong,either high or low.I would agree with you, but the gauge for the WB agrees with what SM and PL are saying. Maybe the WB sensor is no good?
Your narrowband numbers seem correct. I think you are currently a little lean. You can always add 2% and take away 2 % fuel and see how it feels while noting the O2 numbers and spark retard.It feels rich. It doesn't spool as quickly, and feels a little sluggish, but I'm running 7lb less boost too.
I took the car on a 100 mile drive today, and noticed under light acceleration, around 0 vac/boost, the WB was at 10.4-11.0, while the O2 was .730-.760.
I think you're right. The WB is goofy. I'm going to see if it can be calibrated, and I'm going to check the powers and grounds for it too.
If your wideband is correct,you should be able to remove a lot of fuel with the chip and the car should respond in a very noticeable way. Have you tried leaning it out? A chip reset is always something to try. You can also disconnect the narrowband and run it in open loop to test.I really appreciate the help.
The car still isn't fixed. I tested the WB, and it is in fact working properly, and at idle, and low speeds the NB and the WB agree with each other. It's only at hwy speeds, tip-in throttle, and WOT that I'm having issues. I'm bringing my Snap-0n vantage home tomorrow, and will be figuring the POS out on Thursday.
I'm thinking I've got high resistance in a connector somewhere in the O2 ckt, or a flaky ECM.
I detest having to run low boost. I had a '12 5.0 Mustang kick my a$$ today....not happy.![]()
Lowell Used Autoparts has an ecu for $45:
1986
Engine Computer
Buick Regal 1227148 stock #92819 $45 Lowell Used Auto Parts USA-MA(Lowell) E-mail 800-952-9775 / 978-454-4444
Should be,at least,18" after the turbine. Where did you have it mounted?I think I figured one of my issues out today. I mounted the WB sensor just after the first bend in the downpipe. I think the sensor is overheating. I'm going to have to move it and see what happens. Hopefully the sensor didn't get damaged.
