SignUp Now!ill race him
I will be racing him:biggrin:
The car is too violent, power comes on way to fast to run on radials. They are swapping pullies and converters to tame it down a little. He'll be at a race next weekend so I'll see it in action. Should be interesting.
557ci BBChevy with an F3 Procharger on Alky. Engine will make in the 2500 range
If that's the Hub City race, I'm going to try to be there too.
It's a good thing you went to the SB2 heads and bigger turbo now that they are allowing a Procharged BBC on alky to run in that class How much does he have to weigh with this combination??
That's why I went ahead and upgraded now. I'll have to have a lot more power than last year to even have a shot at going rounds.
All Big Blocks, Turbo and blower cars are at 3200
BBC on alky with F3 blower 3200
Small block with turbo, still only 94mm inlet 3200
It kinda sux that the bb guys can weigh what the small block guys have to.
I here there maybe another new face in that class this year sometime.
It will be several. David Reese has the same combo as Brady except it's a 632 or 615 Fulton on Alky with the F3 in a Mustang Coupe. Brandon May took his turbo motor out of his L/S T-bird and I hear it's in a Mustang.
They'll have a hard time competing with Stack in the Monte if they can't get all that power to the ground. We'll be in Hattiesburg this weekend with Stack. He went a 4.92 at 154 Sunday in testing in ORSCA trim with the 94mm plug.
Dusty,
Is that still the same "94MM" turbo as last year?
